Installation guide for Duplicate Invoice Checker
This installation guide consists of three sections that will walk you through a general overview, the setting up of the ML Sensor and the configuration of the views. An additional troubleshooting section can be found at the very end.
The learning goals of the guides are:
Ensure you and your system meet the prerequisites and requirements for the app
Create an understanding of the use case
Create an understanding of the algorithm logic
Support you to set up the ML Sensor for the first time
Support you to set up the front-end of the app
Once these steps have been completed, duplicate results can be validated with the business side and further refinements of e.g. filters can be made.
