Required directories and registry keys for Task Mining
The Task Mining Client software on a user's machine needs access to these directories and registry keys to work as expected. For the full system requirements for the Task Mining Client Software, see Task Mining Desktop Application.
In a virtual desktop infrastructure (VDI) environment, these directories and registry keys must be persisted between sessions. For the VDI options and limitations for Task Mining, see Virtual desktop infrastructure options for Task Mining.
Any references to third-party products or services do not constitute Celonis Product Documentation nor do they create any contractual obligations. This material is for informational purposes only and is subject to change without notice.
Celonis does not warrant the availability, accuracy, reliability, completeness, or usefulness of any information regarding the subject of third-party services or systems.
Directory | Access type | Description |
| Installation directory when installed for all users of a machine. |
| Installation directory when installed for the current user only. |
| Read/write access during runtime. | Contains cached parquet and image files. Can be configured in the project configuration. |
| Read/write access during runtime. | Contains cached configuration, application settings and logs. |
| Logging folder for the Task Mining Client. Contains the current log file |
| Read/write access during runtime. | Contains required application settings. We recommend making the entire |
For further information, see Environment.SpecialFolder Enum. | Write access during runtime. | Contains crash report files. |
For further information, see Environment.SpecialFolder Enum. | Write access during runtime. | Contains error log files if configuration could not be loaded. |
Required registry keys
For
HKMU, when the client is installed for all users of the machine (admin), the key will be underHKLM. When installed for the current user only, the key will be underHKCU.For
<SOFTWARE>: On 32-bit Windows systems, replace withSoftware. On 64-bit Windows systems, replace withSoftware\Wow6432Node.
If the registry key for autostart is not writable, the application will not autostart at system start.
Registry key | Access type | Description |
| Write access during installation. | Registers installation of the application. |
| Activation link to automatically activate the client on the first start. |
| Client certificate subject used for secure gateway authentication. |
| Working directory of the Task Mining client. |
| Custom connection timeout. |
| Custom browser extension IDs for self-hosted rollouts. |
| Host URLs of the secure gateway server. |
| Service principal names used for the on-premise Task Mining gateway. |
| Custom port for the Chrome Extension. |
| Write access during installation. | Update URL of the Chrome Extension. |
| Write access during installation. | Update URL of the Edge Extension. |
| Write access during installation. | Autostart entry for the Task Mining client. |
| Write access during installation. | Registers the Task Mining-specific URL. |
| Write access during installation. | Registers the shell command to open the client from URL. |
| Write access during installation. | Enables browsers to open the Task Mining client from URL. |
