Celonis Product Documentation
Data retention in Orchestration Engine
Here you can find information on how Orchestration Engine data is kept in Celonis Platform:
TTL
Webhook events
7 days
The time Orchestration Engine stores events data sent to the Event-Receiver Endpoint. All events are stored including the unprocessed ones or those failing authentication.
Process context
No TTL for lifetime of tenant
The time you can access data stored inside a process context. Contact Support if you need to request data to be deleted.
Submission data
The time you can access submitted form data. Contact Support if you need to request data to be deleted.
User audit logs
No TTL
The time in which Celonis Audit Logs maintains audit logging information. Link: https://docs.celonis.com/en/viewing-your-audit-logs.html
For general information regarding data retention in Celonis Platform, see Information security and data privacy.
