Understanding Differences Between First-Generation and Premium Process Query Engine Behavior
As part of our efforts to enable scalability and support for more complex, data-intensive processes, we are transitioning from the first-generation engine to a new engine architecture. The Premium Process Query Engine lays the groundwork for handling larger data volumes while maintaining reliable performance and responsiveness.
This shift may lead to differences in query results due to updated logic and computation methods that align with modern standards and ensure optimal performance. This document outlines the most significant and commonly encountered differences, along with guidance on how to validate results and adjust queries when needed to match the behavior of the previous engine. Also deprecated behavior from the first-generation engine announced in the documentation will not be implemented in the premium engine.
Please note that other, more subtle differences may exist and are not exhaustively covered here.
Difference in NOT Filter Behavior for NULL values
The behavior of the NOT operator in filters differs due to how each engine handles NULL values in logical expressions.
| First-generation Engine | Premium Engine | |
| Logic Behaviour | Two-valued logic (TRUE or FALSE) | Three-valued logic (TRUE, FALSE, or UNKNOWN/NULL)* |
NULL in conditions | Treated as FALSE | Evaluated as UNKNOWN (excluded when negated) |
Effect of NOT | NULL values are included in result | NULL values are excluded from result |
*Except for operators IN and MULTI_IN.
Example
| Query |
FILTER NOT ("mytable"."id" = 1); |
First-generation engine: Returns all rows where
idis not 1, including rows whereidisNULL.Premium Engine: Returns only rows where
idis not 1, but excludes rows whereidisNULL.
Recommendation
If your data may include NULLs and you want to preserve first-generation engine behavior, adjust the filter to explicitly handle them:
| Query |
FILTER ( "mytable"."id" IS NULL OR "mytable"."id" != 1 ); |
This explicitly includes rows where id is NULL or not equal to 1, maintaining compatibility with the previous logic.
Difference in Default Sorting
To ensure high performance with large datasets, the Premium Engine does not apply a default sorting to queries unless explicitly specified by the user with an ORDER BY clause. This aligns with standard industry practices. The first-generation engine may have provided a seemingly consistent default order, but this behavior was never guaranteed and should not be relied upon. This can lead to different results between the two engines, particularly with functions that rely on order to determine the result, such as FIRST or LAST.
Example
| Query |
STRING_AGG ( "CASE_TABLE"."ACTIVITY_ID", ', ' ) |
First-generation engine: May return a result like "123, 456, 789"
Premium Engine: May return a different, non-deterministic result like "456, 789, 123" because there is no defined order.
Recommendation
To ensure consistent and predictable results, you should always apply an explicit ORDER BY clause in your queries, especially when using functions where the order of data is critical. This includes operators like FIRST, LAST, STRING_AGG, PU_FIRST, PU_LAST, PU_STRING_AGG, and all window functions.
Difference in Sorting of Eventlogs
Similar to the previous difference, when querying unaggregated columns from an eventlog, such as in an OLAP table component, the Premium Engine does not apply any default sorting. The order of activities is not guaranteed, which can lead to mixed-up cases or an illogical sequence of events.
Example
Consider an OLAP table showing case id and activity names. Without an explicit sorting applied, there is no guarantee that the activities will be displayed in their chronological order based on timestamps. Furthermore, it might also happen that different cases are mixed up.
Recommendation
To view activity sequences correctly within cases, you should:
Always add both the case id and timestamp columns to your view.
Explicitly sort by
case idfirst, and then bytimestampsecond.For performance, it is highly recommended to filter on the specific cases you need, as sorting the entire event log can be computationally expensive.
Difference in Allowance of Duplicated Primary Keys
The First-generation engine was more permissive towards duplicate values in primary key columns. To support advanced functionalities like Augmented Attributes & Tasks and ensure delta readiness for data models, the Premium Engine strictly enforces the uniqueness of primary keys directly during the load.
Recommendation
If you encounter a primary key duplication error when loading a data model, you must go back to your data transformations and modify the necessary SQL queries to remove the duplicates. Once the transformations are corrected, reload the data model.
Approximate and Exact Operators
In both the First-Generation and Premium Process query engines, all operations are performed in an exact manner by default. Additionally, the Premium Process Query Engine allows you to approximate calculations for MEDIAN, QUANTILE, COUNT_DISTINCT, and COUNT_TABLE by using the APPROX keyword. This significantly improves performance and scalability, though it may result in minor deviations from exact values.
Recommendation
We strongly recommend using approximate calculations wherever reasonable, as those yield significant performance gains with little accuracy loss.
