Technical connection for View reports
To configure a View report, see: View Reports.
Before you begin
To configure a technical connection you need Admin access to your Celonis Platform team, giving you access to the Admin & Settings area of the platform:
Configuring a technical connection for View reports
With Admin access to the Celonis Platform team, create a technical connection by following these steps:
  1. Click Admin & Settings.
  2. Click Applications.
  3. Click + New Application and select Reporting application.
  4. Add a name and an optional description and then click Save.
  5. With the reporting application created, return to the View that the report is being configured for and click Options - Permissions.
  6. Locate the reporting application created in step 3, assign it Use permissions, and click Save.
    The technical connection has been established and can now be used when creating and scheduling View reports.
