Method: Numeration of process flow objects
By activating this feature, numberings on the process flow objects are displayed. This is available for for all graphic layouts (horizontal/vertical etc.)
The numbers are displayed on the objects at the bottom right is provided, showing the process steps sorted by applications in vertical or horizontal swimlanes.
NOTE: To use this feature it is required to make settings in the Extended Configuration: Please add a new type Show shape numbers in the “Change” section and, in the Detail Content, select the layouts for which it should be applied.
Please refer to Storage configuration for more details.
